For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... 8-Ball.htm
2017 Victory Vegas 8-Ball on http://www.Totalmotorcycle.com
ROLLING THE DARK STREETS ...
Sinister and blacked out, sparse use of chrome details, and a 21-inch contrast-cut Falchion™ front wheel named after a sword known for its versatility and ready to slice out plenty of attention. This is the Vegas® 8-Ball. Front to back, the Vegas® 8-Ball is sculpted by a tucked-in headlamp, chrome gauge cluster, black risers and pullback handlebars, slash-cut muffler tips and a flush-mount LED taillight. Like its sibling, it runs on a Freedom® 106 V-Twin producing 110 Ft.-Lbs. of pulse-pounding torque mated to a smooth six-speed overdrive transmission. Available in Gloss Black ($12,999).
Attitude from every angle.
2017 Victory Vegas 8-Ball http://www.Totalmotorcycle.com Key Features
Freedom® 106 V-Twin Delivering
110 Ft.-Lb. Of Torque
Falchion™ 21-Inch Front Wheel
Gloss Black
2017 Victory Vegas 8-Ball http://www.Totalmotorcycle.com Features and Benefits
6-Speed Overdrive Transmission
Get comfortable in the passing lane. This 6-Speed Overdrive transmission delivers smooth power, and unmatched power in every gear.
106 Cubic-Inch Freedom® V-Twin
The Victory Freedom® 106/6 V-Twin is smooth, efficient – and extremely powerful. It delivers instant throttle response and outstanding power you can unleash on demand.
21” Falchion™ Wheel
Named after a one-handed sword known for its versatility, Vegas’ new 21-inch front wheel carves the road, and slices out plenty of attention.
Low Seat Height
Sit-low without slouching on this 25.2” seat.
2017 Victory Vegas 8-Ball - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $12999 USD
Canada MSRP Price: $14,999 CDN
Specifications
ABS/Cruise Control Not Equipped
Curb Weight 682 lbs / 309 kg
Displacement 106 ci / 1731 cc
Oil Capacity 5.0 qts / 4.73 ltr
ENGINE & DRIVETRAIN
Valve Train 4 Valves per Cylinder, Hydraulic Lifters & Cam Chain Adjusters
Transmission Type 6 Speed Overdrive/Constant Mesh
Transmission/Primary Drive Gear Drive with Torque Compensator
Transmission/Final Drive Carbon Fiber Reinforced Belt
Exhaust Dual-Staggered Slash-Cut with Common Volume
Drive/Driven Clutch Wet Multi-Plate/Diaphragm Spring
Cooling Air & Oil
Compression Ratio 9.4:1
Charging System 38 Amps Max Output
Battery YTX20HL-BS/12 Volt 18 Amp Hour 310 CCA
Bore x Stroke (mm) 101 x 108 mm
Engine Type Freedom 106/ 6 V-Twin
Suspension
Rear Suspension Single Monotube Gas/Preload Adjustable/3.0" (75mm)
Front Suspension Telescopic Fork/ 5.1" (130mm)
Brakes
Rear Brakes Single 300 x 5mm/ Floating Rotor/ 2 Piston Caliper
Front Brakes Single 300 x 5mm/ Floating Rotor/ 4 Piston Caliper
Brake System Type Not Linked
Tires / Wheels
Rear Wheel 18 x 5.5 in
Rear Tires Dunlop D417 180/55B18 74H
Front Wheel 21 x 2.15 in
Front Tires Dunlop D418F Elite 3 90 90-21 54H
DIMENSIONS
Wheelbase 67.1 in / 1705 mm
Seat Height 25.2 in / 640 mm
Rake/Trail 33° / 5.0 in/ 126 mm
Ground Clearance 5.3 in / 135 mm
GVWR 1,151 lbs / 523 kg
Fuel Capacity (Litres) 4.5 gal / 17 ltr
Overall Length (in./mm.) 96.9 in / 2462 mm
Colors (Base) Gloss Black
