2017 Norton V4RR - Coolness Factor = 76.5%
Your Coolness Factor of the 2017 Norton V4RR is:
View results
2017 Norton V4RR on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... ton-V4.htm
2017 Norton V4 on http://www.Totalmotorcycle.com
V4 RR The TT racer reborn
Lots of motorcycles claim to be bred on the race track, but the new Norton V4 RR is THE TT racer reborn, developed at the worlds toughest race track and now redefined for the road.
Meet the new Norton V4 RR
2017 Norton V4 http://www.Totalmotorcycle.com Key Features
200hp, V4 Superbike...
200hp, V4 engine, 1200cc, tubular aluminum chassis.
2017 Norton V4 - http://www.Totalmotorcycle.com USA Specifications/Technical Details
Price: £28,000 inc VAT.
Engine
Engine type: Norton 72-degree liquid-cooled V4, 1200cc. Chain-driven cams with idler gear for reduced engine height. Titanium inlet valves. Slipper clutch Compression ratio: 13.6:1
Displacement: 1200cc Power: 200bhp + @ 12,500rpm
Cooling system: Liquid-cooled Torque: 130Nm @ 10,000rpm
Bore x Stroke: 82mm x 56.8mm Euro 4: Full compliance including oil thermostat, knock sensors, secondary air injection and EVAP
Fuel injection: Electronic fuel-injection system. Constantly variable inlet tracts. 8-fuel injectors. Full drive-by-wire system independent of front and rear banks of cylinders for ultimate control and feel
Electronic Equipment
Instruments: Full-colour 7-inch HD display with multiple functions. Engine mode adjustability including: Road, Track, and Pro-Race
Quickshift: Full quickshift system and auto down blipper
Electronic aids:
Multi-setting traction-control, wheelie control, launch control and cruise control. Uses six-axis Inertial Measurement Unit (IMU)
Built-in dataloggers:
Full data-logging capability including: lap times, max lean angle, max speed, max throttle and max braking force
Engine modes:
Road, Sport, Pro-Race
Ignition:
Keyless ignition system
Lighting:
Full LED lighting system including super bright low beam & high beam, angel eye DRLs, rear lamps and indicators
Chassis
Type: Aluminium twin tube shotgun chassis, cast outriggers and headstock, polished tubes. (tbc). Engine acts as a structural member
Adjustable geometry: Chassis is fully-adjustable including swingarm pivot and adjustable rake angle. 23.9 degree steering head angle as standard set-up
Swingarm: Braced and underslung single-sided cast swingarm. 570mm long, design developed in conjunction with SG5 TT race bike
Wheelbase: 1430mm
Dry weight: 179kg
Note: Chassis design was developed at the world's most rigorous race track - the Isle of Man TT. The geometry, weight distribution & ergonomics were all tested and developed on the SG5 TT race bike which finished seventh at the Superbike TT and achieved a 131mph average speed lap in 2016 at the hands of Australian rider David Johnson
Front suspension: Ohlins NIX30 system front fork. Fully-adjustable Rear suspension: Ohlins TTXGP Norton bespoke fully-adjustable rear shock
Steering damper: Ohlins damper Fork yokes: Billet machined
Front wheel: Forged Aluminium Rear wheel: Forged Aluminium
Front brake: 2 x 330mm full-floating discs. Radially-mounted Brembo monobloc calipers. Brembo discs and Brembo master cylinder Rear brake: Single 245mm disc. Brembo caliper and master cylinder
Styling
Bodywork: Full carbon-fibre.
Fuel tank: Underseat MotoGP-style 18-litre fuel tank is all carbon-fibre, with Kevlar reinforcement and chemically coated internally to meet fuel resistance standards
Footrests: Forged footrests, footplates and carbon heel guard. Cast sprocket cover
Optional
Full titanium race system aftermarket tune, approx 8kg lighter and approx 10bhp+ as optional accessory
- Note: RACE EXHAUST NOT FOR ROAD USE
Chrome Race Replica bodywork
Carbon Fibre BST Wheels
Dual Seat New V4 RR
Re: This Week: 2017 Norton V4RR - VOTE NOW
As suggested by ceemes this week, the new 2017 Norton V4RR!
Enjoy,
montanalifter
Real Name: Bill
#3 Unread post by montanalifter »
Fastest British bike around the Isle of Mann.
https://www.youtube.com/watch?v=yQJcIUrsC9M
£28,000 ....
Hummm.... that's a real party-pooper right there... but if I saw one, then I would have to say, it's awesome.
200hp, carbon fiber... and I guess you can ride it on the road, thanks to the "Note: RACE EXHAUST NOT FOR ROAD USE" means you'll need to find a street legal exhaust.
But that price... I guess if you were going to race it...
Still, impressive. Now that Norton's given us a £28,000 bike, can we also get a budget Norton so others can actually OWN one?
Featured: December 9th - December 16th, 2016
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=53959
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... ton-V4.htm
Awesome (3 points) 47% [ 8 ]
Cool (2 points) 35% [ 6 ]
Uncool (1 point) 18% [ 3 ]
Fail (0 point) 0% [ 0 ]
Total votes: 17
= a Coolwall Factor of 76.5%
Notes: We don't see a lot of Norton around Total Motorcycle, which is a shame, it's not because I (TMW) haven't tried. Norton's issue is that they just do not produce many models, seeing one is very rare as they are just so expensive and the dealer network is so thin. Like many here, I'm happy Norton is producing the Norton V4RR, but at £28,000, there is another bike we won't be seeing much of either. As I know Norton reads Total Motorcycle, here is my Christmas Wish this year for the TMW Norton fans; Norton, please make a more affordable entry-level bike and ship them over here.
