2017 Indian Springfield - Coolness Factor = 73.0%
Your Coolness Factor of the 2017 Indian Springfield is:
View results
2017 Indian Springfield on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... gfield.htm
2017 Indian Springfield on www.Totalmotorcycle.com
GLORY IN THE RIDE ...
Your perfect road is out there. And there’s only one way to find it: on an Indian® Springfield™, a modern motorcycle equipped with all the touring essentials.
Named after the birthplace of Indian Motorcycle® and designed for a pure riding experience, the Indian Springfield™ features a traditional style, quick-release windshield, black leather rider and passenger saddles, and all-weather, remote-locking saddlebags.
It’s equipped with the most essential touring features but designed for ultimate versatility. It can be stripped down into a cruiser when the windshield and saddlebags are removed or become a fully loaded touring model with Genuine Indian Motorcycle® accessories.
The all-new purpose built trunkcompatible chassis delivers a 25-degree rake and 5.2-inch trail for unmatched handling and balance even when fully loaded.
Now available in two-tone color options, Steel Gray over Burgundy Metallic and Blue Sapphire over Star Silver, the Springfield™ is equipped with the most essential touring features but designed for ultimate versatility. While maintaining the style and luxury Indian Motorcycle is known for, the Indian® Springfield™ carves its own niche in the bagger and touring category.
Named after the birthplace of Indian Motorcycle, the Indian Springfield offers classic styling blended with thoroughly modern technology for a purist's take on both touring comfort and urban versatility. The Springfield can be quickly converted into a cruiser with the quick-release windshield and saddlebags removed, or transformed into a high-capacity touring model with Genuine Indian Motorcycle accessories. Remote locking hard bags and adjustable passenger floorboards come standard along with genuine leather seating, ABS, TPMS, cruise control, and a powerful headlight and dual driving lights. Indian Springfield is offered in Thunder Black or Indian Motorcycle Red. New for 2017 are stunning Steel Gray/Burgundy Metallic and Blue Sapphire/Star Silver two-tone finishes. Starting at $20,999.
AT THE END OF EVERY ROAD IS A STORY.
You. The road. Nothing else. That’s the definition of pure riding. And that’s exactly what you get with the Indian Springfield™, along with features like a keyless ignition. Quick-release windshield. And remote-locking saddlebags. Want more? Add a premium audio system, should you ever want a new soundtrack to go with the satisfying rumble of your Thunder Stroke 111 engine. Be legendary.
2017 Indian Springfield www.Totalmotorcycle.com Key Features
Thunder Stroke 111
A nod to the engine designs of our past, with innovations to power us into the future. That’s the remarkable Thunder Stroke® 111 V-Twin. Air-cooled. With 119 ft.lbs of torque, And two massive pistons that produce the thunderous sound that earned its name. There’s always a high road, and with this award-winning powerplant, getting there couldn’t be more effortless – or more exhilarating.
Springfield is now available in two-tone colours for the first time - Steel Grey over Burgundy Metallic with Silver Stripe and Springfield Blue Metallic over Star Silver.
Thunder Black
Steel Grey over Burgundy Metallic with Silver Stripe NEW
Springfield Blue Metallic over Star Silver NEW
2017 Indian Springfield - www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $20,999 USD
Canada MSRP Price: $26,299 CDN
Engine
Engine Type
Thunder Stroke® 111
Displacement
111 cu in (1811 cc)
Bore x Stroke
3.976 in x 4.449 in (101 mm x 113 mm)
Compression Ratio
9.5 : 1
Electronic Fuel Injection System
Closed Loop Fuel Injection / 54 mm Bore
Drivetrain
Primary Drive
Gear Drive Wet Clutch
Drive/Driven Clutch
Wet, Multi-Plate
Final Drive
2.2 : 1
Performance
Peak Torque
119.2 ft-lbs (161.6 Nm)
Peak Torque RPM
3000 rpm
Gear Ratio (Overall)
1st
9.403 : 1
2nd
6.411 : 1
3rd
4.763 : 1
4th
3.796 : 1
5th
3.243 : 1
6th
2.789 : 1
Suspension
Suspension: Front - Type/Travel
Telescopic Fork / 4.7 in (119 mm)
Front Fork Tube Diameter
46 mm
Suspension: Rear - Type/Travel
Single Shock w/ Air Adjust / 4.5 in (114 mm)
Chassis
Brakes/Front
Dual / 300 mm Floating Rotor / 4 Piston Caliper
Brakes/Rear
Single / 300 mm Floating Rotor / 2 Piston Caliper
Wheels/Front
Cast 16 in x 3.5 in
Wheels/Rear
Cast 16 in x 5 in
Tires/Front
Dunlop® Elite 3 130/90B16 73H
Tires/Rear
Dunlop® Elite 3 Multi-Compound 180/60R16 80H
Exhaust
Split Dual Exhaust w/ Cross-Over
Dimensions
Wheelbase
67.0 in (1701 mm)
Seat Height
26.0 in (660 mm)
Ground Clearance
5.6 in (142 mm)
Overall Height
56.8 in (1442 mm)
Overall Length
101.7 in (2583 mm)
Overall Width
39.0 in (990 mm)
Rake
25°
Trail
5.2 in (133 mm)
Fuel Capacity
5.5 gallons (20.8 liters)
GVWR
1385 lbs (630 kg)
Weight (Empty Tank / Full of Fuel)
830 lbs / 862 lbs (376 kg / 391 kg)
Standard
Standard Equipment
ABS; Cast Aluminum Frame with Integrated Air-Box; Cruise Control; Front and rear Highway Bars compatible with lower weather protection; Indian® Script Tank Badge; Keyless Start; Quick-Release Windshield; Quick-Release Hard Saddlebags, Tire Pressure Monitoring; Adjustable Passenger Floorboards;
Electrical
Gauges
Tank Mounted Electronic Speedometer with Odometer; Dual Tripmeters; Digital Tachometer; Ambient Air Temperature; Fuel Range; Average Fuel Economy; Battery Voltage; Gear Position Display; Real-Time Clock; Vehicle Trouble Code Read-Out; Heated Grip Level (If Heated Grips Installed); Low Engine Oil Pressure; 9 LED Telltale Indicators: High Beam, Chassis Fault, Turn signals (separate), ABS, Neutral, TPMS, Check Engine, Sidestand; Tank Mounted Electronic Fuel Gauge with Low Fuel LED Indicator
Re: THIS WEEK: 2017 Indian Springfield - VOTE NOW
New from Indian for 2017....
Enjoy!
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
#3 Unread post by Gummiente »
totalmotorcycle wrote: Fri Apr 28, 2017 3:27 am - Edited (Mike) due to brain fart comment
Say what?
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
Gummiente wrote: Fri Apr 28, 2017 1:42 pm
Say what?
Doh. :)
LOL.
Gummiente
Years Riding: 38
#5 Unread post by Gummiente »
I got your six, Boss. :mrgreen:
It's THAT you ride
ceemes
Real Name: a big secret
#6 Unread post by ceemes »
Meh.....another big cruiser in an already overcrowded segment.......both the sport bike and cruiser market segments are far too overcrowded, often with manufacturers offering basically the same models but with minor cosmetic tweaks.
markdcoco
Real Name: Mark DiCocco
My Motorcycle: 2014/BMW/R1200RT
#7 Unread post by markdcoco »
Mom always said: "If you don't have anything nice to say, don't say anything at all."
I, for one, love the look of cruisers. This looks very nice. I like it because it doesn't have big fat fairings in the way.
Note: I am going to hold off updating the Cool Wall this week for a day or two as I'm working at the Total Motorcycle 17.2 launch.
I went with: Cool
I'll just put this out on the stoop and see if the cat licks it up but It's 50's retro done right IMO. I think (and I'm not knocking them) H-D could pick up a few styling cues from the Springfield. H-D loves retro, heritage and history. There current batch of cruisers, while are retro-inspired, just don't look retro 50's. And for whatever reason, the 50's are in (Triumph Bobber anyone?). So Indian has done a great job running this up the flag pool and getting people to salute it!
The price is what keeps the 2017 Indian Springfield from being awesome... at $21-26k, that's new car price!
ceemes wrote: Sat Apr 29, 2017 4:25 am Meh.....another big cruiser in an already overcrowded segment.......both the sport bike and cruiser market segments are far too overcrowded, often with manufacturers offering basically the same models but with minor cosmetic tweaks.
True, but from the looks of the 2014-2017 model years, the sportbike and cruiser segment is dying; which is a real shame... Could be then why the manufacturers are not "going out on a limb" anymore.
