For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... ssador.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-Ural-Ambassador1-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-Ural-Ambassador2-small.jpg)
2017 Ural Ambassador on www.Totalmotorcycle.com
In honor of our 75th anniversary we’d like to introduce our newest limited edition, the Ural Ambassador...
Inspired by the extraordinary world travelers and storytellers who chose to brave the adventure and explore the world by sidecar. Our Ural Ambassador is the envoy of good will, a perfect vehicle to connect with people from all walks of life, explore foreign terrains and start a conversation with perfect strangers no matter where the road takes you.
75 years of ups and downs in world affairs couldn’t change one thing – the iconic Urals keep circling the globe, bringing out smiles, creating special bonds and reminding us that adventuring together is better. Here’s to all the Ural Ambassadors already out there, exploring, connecting and sharing the Ural story.
The Ambassador is dressed in elegant bronze metallic colorway with blackened powertrain and new smoked glass rider and passenger windshields to protect both riders. Equipped with 2WD, it can take you through the roughest routes.
2017 Ural Ambassador www.Totalmotorcycle.com Key Features
On-Demand 2WD
Universal Spare Tire & Luggage Rack
Bronze Colorway
Black Jerry Can
Black Engine
Utility Shovel
Sidecar Bumper
Tool Kit
First Aid Kit
Toolbox Gas Tank
Enduro Bench Seat
Sidecar Accessories Panel (Phone / Tablet Charging)
Tan Sidecar Cordura Tonneau Cover
Rubber Floor + Trunk Mats
75th Anniversary Badges
1 Year Rever Premium Membership
2017 Ural Ambassador www.Totalmotorcycle.com Features and Benefits
Total Built for US: 25 units
2017 Ural Ambassador - www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $16500 USD
Canada MSRP Price: $ See Dealers for Pricing in CAD
Engine and Transmission
•Displacement, cc: 749
•Engine type: OHV air cooled 2 cylinder 4 stroke “boxer” (flat twin)
•Valve per cylinder: 2
•Bore and stroke (mm x mm): 78 x 78
•Max output (hp): 41 @ 5500 rpm
•Max torque (ft-lbs): 42 @ 4300 rpm
•Compression: 8.6:1
•Fuel system: Throttle body EFI
•Starting: Electric & Kickstart
•Clutch Double-disc dry
•Transmission type: Manual
•Speeds: 4 forward 1 reverse
•Primary drive (rear wheel): Driveshaft
•Final drive ratio: 4.62
•Engageable sidecar wheel drive: Yes, driveshaft
Physical Measurements
•Overall length, inch.: 98.8
•Overall heights, inch.: 54.3
•Overall width, inch.: 63.6
•Seat height, (unladen), inch.: 32.0
•Ground clearance (unladen),inch.: 6.8
•Dry weight, lbs: 730
Electrical
•Alternator: Denso, Peak Output 40 Amp @ 14vdc, 560 Wt
•Battery: FAYTX20HL (12V, 20A)
•Headlight: H4
•Spark plugs: NGK BPR6HS
Chassis
•Front suspension: IMZ leading link fork
•Rear suspension: Double sided swing-arm with two Sachs hydraulic spring shock absorbers, 5x adjustable
•Sidecar suspension: Single sided swing-arm with Sachs hydraulic spring shock absorber, 5x adjustable
•Wheels: 2.15X19 Aluminum rims with steel spokes
•Tires: Duro HF-308, 4.0×19?
•Front brake: 4-piston fixed Brembo caliper with 295mm floating NG rotor
•Rear brake: HB big bore single piston integrated floating caliper with 256mm fixed NG rotor
•Sidecar brake: 2-piston fixed Brembo caliper with 245mm floating NG rotor
Misc.
•Fuel grade: 91 Octane, unleaded
•Fuel tank capacity, gallons: 5.0
•Reserve, gallons: app. 1
•Estimated fuel economy, mpg: 31-37
•Estimated range, miles: 155-185
•Recommended max cruising speed, mph: 70
•Max permissible weight, lbs:1325
•Trunk volume, cubic ft.: 2.9
Warranty
•2-years parts and labor unlimited mileage.
