For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... GSX-R1000R
2017 Suzuki GSX-R1000R on www.Totalmotorcycle.com
The King of Sportbikes is back, bow to the King…
It has been three decades, with more than a million editions sold, since
the GSX-R line was born. And a decade and a half has elapsed since the first
GSX-R1000 transformed the open sportbike class forever. Now, the 2017 GSX-R1000R
is redefining what it means to be The King of Sportbikes.
This motorcycle’s chassis forms the lightest, the most compact, the
most aerodynamic and the best-handling GSX-R1000 ever. Cradled in the new
aluminum frame is an all-new engine that uses an exclusive Variable Valve
Timing and Ride-by-Wire throttle bodies for a wide spread of power while delivering
smooth and precise throttle response
Using an Inertial Measuring Unit (IMU) the GSX-R1000R’s advanced electronics
package includes selectable performance modes so the motorcycle enhances and
fine tunes rider inputs. The six-axis IMU lets the GSX-R1000R recognize its
position on the street or race track to help the rider achieve an extraordinary
level of riding performance.
Up front, new style BREMBO T-drive brake rotors grasped by Monobloc calipers
connected to the exclusive Suzuki Motion Track Anti-lock Brake system provides
strong, controlled braking. The precise and smooth SHOWA Balance Free suspension
keeps the sticky Bridgestone RS10 tires in touch with the road. All of this
forward-looking motorcycle technology is covered in all-new, wind tunnel-developed
bodywork that’s uniquely GSX-R.
THE KING OF THE SPORTBIKES!
This is your invitation to Own The Racetrack.
*The Traction Control System is not a substitute for the rider’s throttle
control. It cannot prevent loss of traction due to excessive speed when the
rider enters a turn and/or applies the brakes. Neither can it prevent the
front wheel from losing grip.
*The ABS is a supplemental device for brake operation, not a device for shortening
stopping distance. Always remember to reduce speed sufficiently before approaching
curves.
2017 Suzuki GSX-R1000R www.Totalmotorcycle.com
Key Features
All new 999.8cc liquid-cooled DOHC inline-four cylinder engine produces
exceptionally high top-end power without sacrificing low to mid-range power
thanks to a Variable Valve Timing (VVT) system, Ride-by-Wire Throttle Bodies
and more.
Advanced electronics such as an Inertia Measurement Unit (IMU), S-DMS adjustable
power output, and Suzuki traction control, plus other performance features,
increase racetrack and street performance.
New design, twin-spar type aluminum frame is 10% lighter and more compact,
with optimized rigidity for nimble handling and a high level of grip when
cornering.
2017 Suzuki GSX-R1000R – www.Totalmotorcycle.com
USA Specifications/Technical Details
Canada MSRP Price: $ See Dealer CDN
US MSRP Price: $ TBA USD
Engine 999.8cc, 4-stroke, liquid-cooled, 4-cylinder, DOHC
Bore x Stroke 76.0 x 55.1 mm (2.992 x 2.169 in.)
Compression Ratio 13.2: 1
Fuel System Suzuki Fuel Injection with Ride-by-Wire 49mm throttle bodies
Starter Electric
Lubrication Wet sump
Electronics
Traction Control Motion Track Traction Control System (MT-TCS)
Inertial Measurement Unit (IMU) Six direction, three axis motion
Drive Mode New three mode, Suzuki Drive Mode Selector
ABS Motion Track Anti-lock Brake System with cornering ABS
Quick-Shift System Bi-directional Quick-shift System
Launch Control Suzuki Launch Control System
Drive Train
Transmission 6-speed constant mesh
Clutch Wet, multi-plate type
Final Drive Chain drive, #525
Chassis
Suspension Front SHOWA BFF, Inverted telescopic, coil spring, oil damped
Suspension Rear SHOWA BFF-Lite Shock, Link type, coil spring, oil damped
Brakes Front Brembo, Disc, Brembo 4-piston, Disc, twin, ABS-equipped
Brakes Rear Nissin, 1-piston, Disc single, ABS-equipped
Tires Front Bridgestone RS10, 120/70ZR17M/C (58W), tubeless
Tires Rear Bridgestone RS10, 190/55ZR17M/C (73W), tubeless
Fuel Tank Capacity 16 L (4.2 US gal.)
Color TBA
Electrical
Ignition Electronic ignition (Transistorized)
Headlight LED
Tail Light LED
Instrumentation Full LCD with black face
Position Lights LED
Lightweight Battery Yes
Dimensions
Overall Length 2075 mm (81.7 in.)
Overall Width 705 mm (27.8 in.)
Overall Height 1145 mm (45.1 in.)
Ground Clearance 130 mm (5.1 in.)
Seat Height 825 mm (32.5 in.)
Curb Weight 203 kg (448 lbs.)
