Need some glue for grips
nyrblue35
#1 Unread post by nyrblue35 »
Just put some nice iso grips on my bike and after letting the left grip set for a few hours i noticed its not as tight as it should be and yet i used the whole tube of glue supplied although it was rather tiny. tomorrow i might see if i can wiggle it off. can you use 100% silicone that you can get at a home depot? just looking for the cheapest alternative since ill be using it just once really. thanks
See my bike and accessories at
www.CruiserCustomizing.com/nyrblue35
ZooTech
Years Riding: 18
#2 Unread post by ZooTech »
I have tried alternatives in the past, from contact cement to silicone to epoxy, and none of them work. Grip glue must be magic stuff or something. :?
nyrblue35
#3 Unread post by nyrblue35 »
ZooTech wrote:I have tried alternatives in the past, from contact cement to silicone to epoxy, and none of them work. Grip glue must be magic stuff or something. :?
ha, maybe my tube was defective. :frusty:
Itzamna
#4 Unread post by Itzamna »
You won't believe me when I tell you this, I didn't either, but use hairspray. I had to replace my handlebars the other night and completely forgot about glue. I had read on my SV1000 forum to use hairspray. It worked better than any glue I've used on my grips before.
It lubes it up at first to make it real easy to slide on. Then once it dries it's very sticky. I think I read that it actually melts into the rubber, creating even a better grip. Had it on for a week, and that thing will not budge period!
Try it, I'm telling you that you will be suprised.
Brian
'03 Suzuki SV1000
nyrblue35
#5 Unread post by nyrblue35 »
well unfortunately id like to try the hairspray method but it seems since the glue set i cant really get the left grip off although i can still twist it. :roll:
the plastic insert is glued good but yet the grip can still twist. i dont see anyway i can get this grip off w/out damaging it so ill just have to leave it as is. it doesnt twist while im riding its just one of those annoying things thats in the back of my mind, you know? :frusty:
oldnslo
Real Name: Lamont Cranston
Years Riding: 20
#6 Unread post by oldnslo »
Hairspray is the ticket. Done it many times, always works. Avoid using silicone to remove grips if possible, as it will cancel out the stick in the hairspray.
John
"83 XJ900RK
Iain
#7 Unread post by Iain »
That blew my mind away, I can't believe the hair spray trick works, but my grips arn't goign anywhere. Any other home remedies I should know about?
DocXander
grips
#8 Unread post by DocXander »
The grips on my Ninja are made of PVC, I used PVC plumbing cement. Those suckers are on permanent. Will have to cut them off if I ever want to change them. However, when I put 'em on, I was less concerned about getting them off down the road than I was to have them move at at all while on the road... dig?
DocXander
SCRC 443 Victoria
1995 Suzuki VS800 Intruder
1982 Yamaha Maxim 400
Life is a Highway... wanna go for a ride?
kar_the_terrible
#9 Unread post by kar_the_terrible »
think I'll try the hairspray
'78 Yamaha XS400
'86 Yamaha Radian
oldnslo
Years Riding: 20
#10 Unread post by oldnslo »
Another helpful hint--a Big Mac will sometimes cure constipation.
John
"83 XJ900RK
