Bowl Gasket Expansion
shoey949
#1 Unread post by shoey949 »
One of the bowl gaskets on the carb on my '82 nhawk is leaking gas passed it. I took it off and the gasket has expanded. I have tried using all sorts of liquid gasket stuff in addition to the rubber gasket. Is there way to treat the rubber gasket so that it will not expand?
Thanks,
Nate
1973 Honda Cl 350 (Sold)
1982 Honda 650 Nighthawk
1978 Kawasaki KZ 400 (Sold)
1983 Kawasaki GPZ 550
But someone will say, "You have faith; I have deeds."
Show me your faith without deeds, and I will show you my faith by what I do.
James 2:18
TechTMW
#2 Unread post by TechTMW »
Nope/ Ime for new gasket. They're not that expensive, and the liguid stuff's just going to clog your sytem over time. Maybe you can get some Cork gaskets (Or make some) that won't expand ...
The gasket probably got carb cleaner on it at some point (this causes rubber to expand)
shoey949
#3 Unread post by shoey949 »
well, I have previously had all the bowls leak, and all the gaskets were expanded, but I dried them out and put them back in and now just one is leaking. I don't know if the others have expanded cause they aren't leaking and I don't want to take them off if its not leaking.
James 2:18
