screw idle!
sidecarguy
screw idle!
#1 Unread post by sidecarguy »
does the idle misture screw
affect the bike at higher rpm?
or is it just for iddling?
meaning does it affect the mixture while cruising?
:littlebike5:
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
TechTMW
#2 Unread post by TechTMW »
just idling
All it does is set the gap that the throttle butterflys have when the throttle is closed.
sidecarguy
#3 Unread post by sidecarguy »
hmm ok that what i thought
but heard somewhere that it does.
and then i kinda thought my bike did,
not accelerate ok when too lean!
so once the accelalator takes over it dont matter?
ill have to tell my bike u said so :frusty:
anyway its a 2 stroke
so its kinda hecktic anyway!
anyone know anything about the yamaha ag200?
went to the dealer and it was soo cheap!!
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
flynrider
#4 Unread post by flynrider »
TechBMW wrote:just idling
Tech,
I agree with the idling only part, but doesn't the idle speed screw set the butterfly gap and the idle mixture screw (often plugged on newer bikes) regulate the air/fuel mixture in the idle circuit?
Bikin' John
'93 Honda CB750 Nighthawk
nitrus
#5 Unread post by nitrus »
Tech,
the idle mixture screw does indeed control the idle circuit, which is a circuit that flows fuel at all throttle openings. :P
ZooTech
Years Riding: 18
#6 Unread post by ZooTech »
sidecarguy wrote:hmm ok that what i thought
You certainly must be
A master of Haiku.
Because your posts are often
Structured in similar fashion.
Or it could be that
Your screen resolution
is set at a mere
eighty by sixty.
:laughing: :wink:
#7 Unread post by Sev »
5
7
5
I'm not a poet
Though I always try my best
My Haiku have to many syllables
sidecarguy
#8 Unread post by sidecarguy »
lol :roll:
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
TechTMW
#9 Unread post by TechTMW »
Tech,
Yes. :laughing: Sorry for the (my) confusion. It still only affects the bike at idle. Due to the nature of vaccuum and venturi (bertolli's priciple, etc) when the throttle opens about 1/8th of the way, the needle jet/jet needle control the fuel/air mix entering the cylinder..
