starting trouble
mystyle101
starting trouble
#1 Unread post by mystyle101 »
well heres the problem, i have a 2002 suzuki gsxr 750 and it isnt starting at the moment, the bike runs because i can pop the clutch and start her up. the battery is good, its just when its in nuetrul and i pull the clutch in and hit the starter switch, nothing happens. the switch is good, but i still cant figure out what the problem is. If anyone has had a similar problem or maybe knows what it might be please post.....im really boggled on what it could be. thank you.
Skier
Re: starting trouble
#2 Unread post by Skier »
mystyle101 wrote:well heres the problem, i have a 2002 suzuki gsxr 750 and it isnt starting at the moment, the bike runs because i can pop the clutch and start her up. the battery is good, its just when its in nuetrul and i pull the clutch in and hit the starter switch, nothing happens. the switch is good, but i still cant figure out what the problem is. If anyone has had a similar problem or maybe knows what it might be please post.....im really boggled on what it could be. thank you.
The neutral switch could be bad, or the wiring from it. If the bike thinks you are in gear it most likely won't make the starter turn over. Do you have the green neutral indicator light showing?
mystyle101
#3 Unread post by mystyle101 »
yes the green nuetrul light comes on, were exactly is the neutral switch located at? and is there a way i could trick the bike into thinking its in neutral? thanks.
nitrus
#4 Unread post by nitrus »
You said you can push start it? The neutral switch is located on the shift mechanism inside the left side case. check the wires going into the clutch lever.
