gas tank
Gnarlyroad
gas tank
#1 Unread post by Gnarlyroad »
Anyone have some tips on removing the last of the gas from a tank. I'd like to paint , but don't want fuel slopping around or dripping while doing so.
Mintbread
#2 Unread post by Mintbread »
Open the cap and wait...
storysunfolding
Years Riding: 22
#3 Unread post by storysunfolding »
one of the lines with a bulb for siphoning gas from a car. works for me
My Blog
Grasp life by the handlebars
Britjoe
#4 Unread post by Britjoe »
A Match?
logitech104
#5 Unread post by logitech104 »
Britjoe wrote:A Match?
:laughing: -For the impatient-
Drain all of the gas out, open the cap and let it sit in the sun until it's all evaporated, mask off, sand, prime, paint, clearcoat.
I rinsed mine out with water and then immidiately set it in the sun to evaporate faster, you might have a rust issue with that option though.
Andrew
#6 Unread post by Andrew »
May not be much left to repaint
2004 BMW K1200RS
[img]http://www.bmwlt.com/forums/images/smilies/BMWsmile.gif[/img]
roscowgo
#7 Unread post by roscowgo »
You could always rig up some kind of cocnut radio ala The Professor, and use the remaining gas and the rear wheel of your bike to power it.
logitech104
#8 Unread post by logitech104 »
roscowgo wrote:You could always rig up some kind of coconut radio ala The Professor, and use the remaining gas and the rear wheel of your bike to power it.
what does that have to do with anything? :roll:
weirdoooo :laughing:
NorthernPete
Years Riding: 11
#9 Unread post by NorthernPete »
a small amount of gas shouldnt take long to evaporate out of the tank.
2009 GS500F
bluebeard
#10 Unread post by bluebeard »
you shouldn't ha ve any problem if you drain gas and let sit for a couple of hours. duct tape the gas cap and petcock (also fuel pump if injected) to keep out trash. Do not rinse with water as you WILL have a rust issue when you are done. If you need me contact me through:
http://www.bluebeardgrafix.com
hope it helps....bluebeard
