gas tank
- Gnarlyroad
- Veteran
gas tank
Anyone have some tips on removing the last of the gas from a tank. I'd like to paint , but don't want fuel slopping around or dripping while doing so.
- storysunfolding
- Years Riding: 22
- logitech104
- Legendary 500
Britjoe wrote:A Match?
Drain all of the gas out, open the cap and let it sit in the sun until it's all evaporated, mask off, sand, prime, paint, clearcoat.
I rinsed mine out with water and then immidiately set it in the sun to evaporate faster, you might have a rust issue with that option though.
- logitech104
- Legendary 500
what does that have to do with anything?roscowgo wrote:You could always rig up some kind of coconut radio ala The Professor, and use the remaining gas and the rear wheel of your bike to power it.
weirdoooo
- NorthernPete
- Legendary 3000
- Real Name: Pete
- Years Riding: 11
you shouldn't ha ve any problem if you drain gas and let sit for a couple of hours. duct tape the gas cap and petcock (also fuel pump if injected) to keep out trash. Do not rinse with water as you WILL have a rust issue when you are done. If you need me contact me through:
http://www.bluebeardgrafix.com
hope it helps....bluebeard
