zzr1100c strange problem - Total Motorcycle Community Forums
Skip to content
  • Quick links
  • FAQ
  • Login
  • Register
  • Print view
7 posts • Page 1 of 1
Ozaki
  • Quote
#1 Post by Ozaki » Sun Jan 25, 2009 7:50 am
Hi there
Have a strange problem guys, I hope someone can help.
When pull off and what the most power the bike feels like it jumps out of gear @ 8000 rpm but shut off the throttle and it goes fine with no problems but will not go higher than 8000 rpm, is it clutch related? or gearbox related? what will it do to my engine if i leave it like this?
Engine has new bearings fitted and I don't want to damage anything again.
Regards
Ozaki
Adrenaline Junkie
Adrenaline ?
dot 2 dot @ 300 K +
fireguzzi
Real Name: Trevor
  • Quote
#2 Post by fireguzzi » Sun Jan 25, 2009 8:06 am
Could be clutch or gearbox. The first and easiest thing I would check though is the chain tension and the condition of the sprockets.
Ozaki
New chain and sprockets
  • Quote
#3 Post by Ozaki » Sun Jan 25, 2009 8:18 am
checked all the final drive, no problem here
Adrenaline Junkie
Adrenaline ?
dot 2 dot @ 300 K +
  • Quote
#4 Post by Johnj » Sun Jan 25, 2009 8:51 am
How about the final drive sprocket?
Ozaki
  • Quote
#5 Post by Ozaki » Sun Jan 25, 2009 9:09 am
sprockets look fine, chain looks fine too
Adrenaline Junkie
Adrenaline ?
dot 2 dot @ 300 K +
  • Quote
#6 Post by Wrider » Wed Jan 28, 2009 9:20 am
I'd vote to check your timing. I've heard of that happening when people have put in new cam chain tensioners without retracting them first... Is it very responsive below the 8k?
Does the engine rev above 8k when not in gear?
Ozaki
  • Quote
#7 Post by Ozaki » Wed Jan 28, 2009 11:11 am
I have not tried to get it above 8K in the stationary mode, will try and let you know.
Adrenaline Junkie
Adrenaline ?
dot 2 dot @ 300 K +
  • Print view
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
