2014 Harley-Davidson Street Glide Special: Coolness = 60.3%
Your Coolness Factor of the 2014 Harley-Davidson FLHXS Street Glide Special is..
View results
Re: This week: 2014 Harley-Davidson Street Glide Spc: Vote T
#11 Unread post by totalmotorcycle »
UPDATE: So it appears from the Patent, the Street Glide isn't cooled then? As it looks like it needs the plastic shrouds which contain the radiators like the Electra Glides...? Can that be?
I found the official US Patent for the design:
https://www.google.com/patents/US201101 ... CDsQ6AEwAQ
Publication number US20110114044 A1
Publication type Application
Application number US 12/621,240
Publication date May 19, 2011
Filing date Nov 18, 2009
Priority date Nov 18, 2009
Also published as DE102010044041A1
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
#12 Unread post by Gummiente »
After perusing the HD website, I finally found the answer buried deep within all the videos and pop-up menus of the Project Rushmore section; the only bikes that get the Twin-Cooled motor are the stock and CVO versions of the Electra-Glide Ultra Classic, Ultra Limited and Tri-Glide Ultra. Good catch, Mr High Side!
It seems the focus of the "select" bikes is more on the new options rather than the new motors. One tidbit I missed in all the hype was the introduction of the electronically linked "Reflex ABS" brakes on 5 of the models.
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
#13 Unread post by totalmotorcycle »
Gummiente wrote:After perusing the HD website, I finally found the answer buried deep within all the videos and pop-up menus of the Project Rushmore section; the only bikes that get the Twin-Cooled motor are the stock and CVO versions of the Electra-Glide Ultra Classic, Ultra Limited and Tri-Glide Ultra. Good catch, Mr High Side!
What an awesome discussion so far!! :cowboy: :cowboy:
Thanks for doing that research last night. So that's quite interesting then, as the Street Glide (obviously) is using the High Output Twin Cam 103™ engine, but then if it's not liquid cooled, still gains the roughly 10% more torque vs the standard 103 engine. This is something that doesn't make sense (to me) as H-D would not have needed to liquid cool any of the engines at all to get the same torque OR would have put the +10% non-liquid cooled engines into their entire line up as it didn't need "anything else"?
Thus:
2014 Harley-Davidson FXDB Street Bob
(definitely NOT liquid cooled and not the High output 103 engine)
PERFORMANCE
Engine Torque Testing Method - J1349
Engine Torque 2 - 98.8 ft-lb
Engine Torque (rpm) - 3,000
Lean Angle, Right (deg.) - 30
Lean Angle, Left (deg.) - 31
Fuel Economy: Combined City/Hwy 5 - 43 mpg
(non-liquid cooled?)
PERFORMANCE
Engine Torque 2 - 104.7 ft-lb
Engine Torque (rpm) - 3,250
Lean Angle, Right (deg.) - 32
Fuel Economy: Combined City/Hwy 5 - 42 mpg
2014 Harley-Davidson FLHTK Electra Glide Ultra Limited
(liquid cooled we know for sure)
PERFORMANCE
Engine Torque 2 - 105.5 ft-lb
Engine Torque (rpm) - 3,750
Lean Angle, Right (deg.) - 31.9
Lean Angle, Left (deg.) - 31.8
Grey Thumper
Real Name: Dino
#14 Unread post by Grey Thumper »
Gummiente wrote:It seems the focus of the "select" bikes is more on the new options rather than the new motors. One tidbit I missed in all the hype was the introduction of the electronically linked "Reflex ABS" brakes on 5 of the models.
Happen to know if "Reflex ABS" lets you use the rear brake on its own? I've got linked brakes, but I can use my rear brake on its own (pretty useful for slow speed maneuvering). I actually wish my brakes weren't linked, since I don't see the point, to be honest.
Gummiente
Years Riding: 38
#15 Unread post by Gummiente »
Grey Thumper wrote:Happen to know if "Reflex ABS" lets you use the rear brake on its own?
It took me a while, but I found this item in a review posted on the Overdrive website; "The system connects the brakes between 32 and 40kmph. Lower speeds or higher speeds allow the brakes to be operated independent of each other". I guess that explains why they are electronically linked.
I've never owned a bike with ABS (but have ridden a few) and while I do like the idea behind it, I'm not sure if linked brakes are a good idea at any speed. in fact, on a sidecar equipped motorcycle they would actually be more of a danger than a help in certain situations.
It's THAT you ride
#16 Unread post by Wrider »
I'm with you guys, I like abs but am not a fan of linked brakes by any means.
#17 Unread post by totalmotorcycle »
I might have a chance to see a new 2014 H-D 103 high output tourer in the "flesh" this week from a local dealer. If I do, I'll ask them about the cooling on this model. :D
storysunfolding
Years Riding: 22
#18 Unread post by storysunfolding »
Yeah- how the cooling works on which models is still a mystery for me. I give it a cool for the updates but the styling is still dated.
My Blog
Grasp life by the handlebars
BobK
Years Riding: 43
#19 Unread post by BobK »
I vote "cool". I've never ridden one of the big Harleys, but long rides on my Sportster leave me numb in the nether regions, and that one looks very comfy.
Chabu
Real Name: Charlie
Years Riding: 2
My Motorcycle: 2013 Triumph Tiger 800
#20 Unread post by Chabu »
That is a thoroughly ugly bike in so many ways so I had to vote fail.
