Motorcycles and Traffic Lights
Joe Rocket=>
#1 Unread post by Joe Rocket=> »
I found a company out there called signal sorcerer and they have these little inductive strips that you put on the bottom of your bike. They say that it is suppose to increase your bikes inductance, causing the signal to change. I was just wondering if anybody uses these or know anybody that has used these before and do they work.
#2 Unread post by Sev »
I think products like those are a waste of money.
Chris8187
#3 Unread post by Chris8187 »
One good thing about living in northeast. Always got those timed lights, so no need for those gadgets.
jmillheiser
#4 Unread post by jmillheiser »
I make it a point to try to avoid sensor lights, or make sure im following a cage when I come up to one
DivideOverflow
#5 Unread post by DivideOverflow »
All lights around here are sensor lights. Ive never had a problem setting them off either.
2008 BMW K1200S
2003 Z1000 - For Sale
2004 Hyosung GV250 - sold
storysunfolding
Years Riding: 22
#6 Unread post by storysunfolding »
I don't understand how this could be a problem. From time to time I run across a light that won't detect me, so I do the same thing I used to do on my bicycle. I put the kickstand down. If it works on a trek, it should work on anything...
My Blog
Grasp life by the handlebars
jmillheiser
#7 Unread post by jmillheiser »
I do have a problem with not setting off the light sensors. I have had to wait for a cage to set it off a couple of times, and had to step off my bike and push the lil button once
#8 Unread post by Sev »
I just take a right if the light won't change. Then flip a u-turn or make a left somewhere else to get where I need to go.
Joe Rocket=>
#9 Unread post by Joe Rocket=> »
I just think that it really sucks when your at a busy 4 way intersection and your the only one in the turning lane and can't get an arrow.
scan
#10 Unread post by scan »
I have the problem here in Ohio. Some won't change with the kick stand trick, the stopping and starting engine trick, or the aligning yourself with the lines trick. I'm always ready to turn right, or try to move up with other traffic. It does annoy me when I can see I'm coming to one and I wonder if I should alter my directional plans.
* 2003 Kawasaki ZRX1200R *
