Forgot to do something...
When I put my bike away for winter I forgot to change the oil as I usually do, I am kind of worried, will this have any effect on the bike? I put it away in december (kinda late i know) and just slipped my mind.
Is it safe to start in less then a month, planning to take it and get an oil change as soon as the horrid snow goes away,
thanks
thanks
'It is the mark of an educated man to teach without a thought.' - Aristotle
- jonnythan
Re: Forgot to do something...
Change the oil before you start it up!BoGs wrote:When I put my bike away for winter I forgot to change the oil as I usually do, I am kind of worried, will this have any effect on the bike? I put it away in december (kinda late i know) and just slipped my mind.
thanks
- jonnythan
It's been sitting around for months. Just be sure to let it drain fully.BoGs wrote:wont the oil be all viscous and be all that much harder to change the oil now? its around -12 here..... plus I never changed the oil myself :S nor do I have the tools.
I have a 2007 triumph daytona 675
And you might want to wait for it to warm up just a tad before you change it, unless you plan on riding at -12
The manual says to torque the drain plug and filter to a certain Nm I do not have a torque wrench, any recommendations on a torque wrench or even if its required... changed the oil on my old gs500 but this has specific torques...
thanks
thanks
- jonnythan
It's not a big deal. Every vehicle has torque specs for the bolt. Just tighten it down.BoGs wrote:The manual says to torque the drain plug and filter to a certain Nm I do not have a torque wrench, any recommendations on a torque wrench or even if its required... changed the oil on my old gs500 but this has specific torques...
thanks
Talking to a friend and he said that it should be ok to drive it to the service center.... just worried its my baby :Sjonnythan wrote:It's not a big deal. Every vehicle has torque specs for the bolt. Just tighten it down.BoGs wrote:The manual says to torque the drain plug and filter to a certain Nm I do not have a torque wrench, any recommendations on a torque wrench or even if its required... changed the oil on my old gs500 but this has specific torques...
thanks
I might have to change the oil myself
Any suggestions?
- jonnythan
It's not going to be that big of a deal either way, really. But, personally, I would not try to fire up my engine with oil that has been sitting around static in the crankcase for over 3 months.BoGs wrote:Talking to a friend and he said that it should be ok to drive it to the service center.... just worried its my baby :Sjonnythan wrote:It's not a big deal. Every vehicle has torque specs for the bolt. Just tighten it down.BoGs wrote:The manual says to torque the drain plug and filter to a certain Nm I do not have a torque wrench, any recommendations on a torque wrench or even if its required... changed the oil on my old gs500 but this has specific torques...
thanks
I might have to change the oil myselfthe fairing is hell and i have an alarm too so even more fun :S
Any suggestions?
You'll probably save yourself a ton of money by doing your own anyway
- storysunfolding
- Years Riding: 22
Grab a manual or grab a friend and change the oil yourself.
My local dealer charges $80 including filter and oil for an oil change on my v-strom.
Were I to buy a socket set, a torque wrench, catch pan, funnel, synthetic oil and a nice filter it wouldn't cost me that much. Though I usually just use dino oil and a filter for a total cost of $15.
It's very easy, open fill spout, put catch pan under oil drain bolt, remove drain bolt, let drain, replace drain plug
Remove filter, replace filter (if it's a screw on type, rub a bit of oil on the oring).
Add oil
Yay!
Add oil
Yay!
