For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... 1100RR.htm
2017 Aprilia Tuono V4 1100RR on http://www.Totalmotorcycle.com
For the fastest and sportiest naked ever...
A direct descendant of the RSV4, four-time World SBK champion, a new evolutionary step has arrived which allows exceptional levels of performance to be achieved.
The new, sophisticated electronic management includes an advanced dynamic controls package with APRC, cornering ABS, pit limiter and cruise control.
The inimitable 175 HP V4 earns Euro 4 approval, without sacrificing any of its superb performance. Suspension and brakes have been improved.
The Tuono V4 family of motorbikes is made up of two distinctly outfitted models. Tuono V4 1100 RR represents an exceptional thrill machine, the heir to a dynasty of naked sport bikes acclaimed by critics as the most effective and fastest bike in its segment.
Tuono V4 1100 Factory is the more exclusive version, dedicated to an extremely demanding public; this bike is equipped with components which are largely derived from the Aprilia RSV4 RF superbike. The evolutionary step that Aprilia presents for 2017 involves both models which, as before, therefore continue to stand out for their factory outfitting and the graphics.
There are big innovations in the on board electronics department. Aprilia Performance Ride Control is the patented control suite derived directly from the winning technology in world Superbike, the most complete and refined of those available on the market. The fourth generation of APRC, standard on the Tuono V4 1100, fits in perfectly with the fine electronic management of the new, full Ride-by-Wire throttle.
The Tuono V4 1100 is now fitted with the advanced multimap Cornering ABS system, developed in collaboration with Bosch to guarantee maximum safety on the road, without sacrificing any performance on the track. The new ABS system works in unison with the Aprilia RLM (Rear Liftup Mitigation) system that limits the lift of the rear wheel during more abrupt braking. Cornering ABS, fine-tuned in accordance with Aprilia's specific indications, is adjustable to three levels of sensibility and can be switched off. In order to allow riders with various levels of experience to find the best possible combination, each of the three Cornering ABS maps can be combined with any of the three new engine maps (Sport, Track, Race). The latter are all three "full power" and differ in the way they dole out the 175 HP of which the Aprilia V4 is capable, in addition to the percentage of engine brake dedicated to them.
BIKE
The fastest and sportiest naked
The latest and most spectacular evolution of a sport naked dynasty, born in 2002 out of Aprilia's intuition to strip down and fit a handlebar on their flagship superbike (which at the time was the V-twin RSV mille), thereby combining all the advantages of a chassis par excellence with the fun of sitting up and dynamic riding. The patriarch of the new “supernaked” category was called the Tuono 1000 R, the first ultra high performance naked. Aprilia Tuono has therefore always been a high handlebar superbike, unbeatable on the track and loads of fun on the road.
The know-how acquired in years of victorious competition at top levels and the experience of the Tuono history now allow Aprilia to exceed limits which had previously seemed insurmountable: introducing the Tuono V4 1100, an exclusive thrill generator and fun in its purest state. 175 HP engine with a powerful maximum torque of 121 Nm, revamped chassis setup to achieve better agility, fine tuned APRC, new look, the possibility of connecting your smartphone to the vehicle through the V4-MP platform.
ENGINE
Higher performance than the V4
The primary goal of the changes made to the already extraordinary Aprilia Tuono V4 engine was to increase torque, especially at medium-low revs in order to increase effectiveness and riding pleasure on the road. To achieve this goal the engine capacity was increased to a full 1077 cc thanks to the cylinder bore which was taken from 78 to 81 mm. This increase in displacement also resulted in higher top performance: the power peak went from 170 to 175 HP and places the Tuono V4 1100 range at the top of its segment (already at 8,000 rpm almost 20 HP more than before are available). This makes the sport naked from Noale excel as a complete weapon for thrills and effectiveness with superlative torque values that dominate on the road and uncompromising top performance to dominate on the track.
The Tuono V4 1100 is the only naked powered by a 65° V4 engine° with unique characteristics. The narrow V architecture made it possible to build an engine with incredibly reduced longitudinal bulk which favours centring the weight and creating a compact chassis. As in previous models, the monobloc crankcase with integrated aluminium cylinder liners ensures maximum rigidity and consistent performance. The upper half of the engine case is now made with shell casting and has been lightened and reinforced; it also now has an optimised ventilation system in order to reduce power loss due to the internal pumping of the crankcase chambers. Also, the crankshaft now has connecting rod pins reduced to 36 mm in diameter with a weight increase of 0.45 Kg, the pistons are new and the Pankl connecting rods are lighter by a total of 400 grams.
The other technical particulars which made this engine so popular have remained unchanged, such as the removable gearbox and the innovative timing system kinematics: the chain camshaft drives only the intake camshaft which in turn drives the exhaust camshaft via a single gear. This solution allows for extremely compact heads especially in the area beneath the frame spars, much narrower than would otherwise be possible. A countershaft dampens vibrations even more than in a 90° V engine.
Full Ride by Wire technology eliminates any direct connection between the throttle grip and the throttle valves, which are entirely controlled by a latest generation Marelli control unit that also controls the ignition and the four injectors. Each bank is fuelled by two throttle bodies managed by a dedicated servo unit.
The powerful engine ECU now allows the three maps to be more easily managed, each one of which corresponds to a different engine power output and now also to a dedicated engine brake management map. The two classic engine management logics Track e Sport, are now joined by a Race map, the most extreme and suited for professional use of the bike on the track with engine braking control reduced to a minimum in order to support more abrupt braking. All three maps are more manageable and less aggressive than the previous version, allowing a better relationship between the opening of the throttle and the torque sent to the wheels. This is a solution that provides further advantages, such as reducing rear tyre wear and better management of the significant power that the Aprilia V4 is capable of developing.
FRAME
World Champion chassis
Simply incomparable, now more than ever. There is no other naked bike as sporty and effective as the Tuono V4 1100; its close derivation from the six-time world SBK champion is clear when you look at the beautiful double rail frame made from pressed and cast brushed aluminium elements, a structure that boasts unrivalled balance between torsional stiffness and flexibility; the 65° V4 engine is set inside it in all of its purity and uniqueness, just like a precious stone set in a ring. In order to make the Tuono V4 1100 more agile on the road, without losing its legendary fierceness on the track, the headstock angle was changed from 25.1° to 24.7° and the fork advancement went from 30 mm to 35 mm for a trail that went from 107.4 mm to 99.7 mm. These sleeker chassis dimensions combine with the 4 mm longer aluminium swingarm, the various suspension setups and the consequent adjustment of the electronic controls, including the wheelie control feature, to obtain a rock solid chassis at high speeds but more agile in direction changes.
Tuono V4 1100 RR is fitted with a high quality suspension: the upside-down Sachs fork with 43 mm stanchions has separate “one by one” hydraulic adjustments in compression and rebound as well as spring preload adjustment on both stanchions. The Sachs shock absorber with built-in piggy back allows the hydraulics to be adjusted in rebound and compression, as well as spring preload adjustment. The standard calibration on both units is functional to the increased performance of the V4 engine and the revamped chassis dimensions and it also takes into consideration use of the bike on the road without any prejudice to the possibility of personalisation in order to obtain maximum accuracy and precision in true racing style riding.
The more refined Factory version of the Aprilia Tuono V4 1100 comes with par excellence standard equipment unique in its category, borrowed from the king of superbike, the Aprilia RSV4 RF. The suspension section is made up of a trio of Öhlins elements (fork, rear shock absorber and steering damper) characterised by ultra fine tuning possibilities and a base setup that has been calibrated to give the rider maximum performance feedback in sport riding.
The braking system on the Tuono V4 1100 has a pair of refined Brembo monobloc M432 callipers on the front which mounts pads with the best possible friction coefficient that grip lightweight aluminium flanged discs (for Tuono V4 1100 Factory). The cast aluminium wheel rims are the same for both models: their lightweight quality contributes to a maximum reduction of the gyroscopic effect, all to the advantage of great handling. Tuono V4 1100 Factory is shod with the sportier Pirelli Diablo Supercorsa, with a wider 200/55 on the rear, in any case approved for street use and available for the Tuono V4 RR as well.
TECHNOLOGY
APRC The top of the line in electronic controls
The Tuono V4 1100 range has received all the upgrades to the already exceptional APRC system that was first seen on the RSV4 RR and RSV4 RF.
As everyone knows, APRC (Aprilia Performance Ride Control) is the patented control systems package derived directly from the winning technology in the world Superbike championship, the most complete and refined of any on the market, which provides tyre circumference self-calibration features and wheelie control. The third generation of APRC, standard equipment on the Tuono V4 1100 units, fully integrates with the fine full Ride-by-Wire multimap electronic management of the revamped V4 engine. As always, the Tuono V4 benefits from a specifically developed calibration, but it has been evolved even further in order to provide maximum thrills on the road and maximum performance on the track.
The Tuono V4 1100 RR and Tuono V4 1100 Factory APRC include:
- ATC: Aprilia Traction Control, adjustable on the fly, (without having to release the throttle) to 8 settings thanks to a practical joystick on the left side of the handlebar, now has even more fine tuned and higher performance operating logic. The percentage of slippage allowed also differs depending on the speed in the turn: the system's performance is smoother and guarantees high support in long sweepers at high speeds without penalising grip coming out of slow turns;
- AWC: Aprilia Wheelie Control,with 3 selectable settings, has been recalibrated to be even more sporty in map 1, whilst still guaranteeing a slight lift in quick acceleration and subsequent smoother descent of the front wheel to the tarmac;
- ALC: Aprilia Launch Control, the assisted starting system for use on the track only with 3 settings;
- AQS: Aprilia Quick Shift electronic gearbox for ultra-fast shifting without closing the throttle or using the clutch.
In addition to the third generation APRC, the Tuono V4 1100 range is fitted with the highly advanced Race ABS system, developed in collaboration with Bosch to guarantee maximum safety on the road, without sacrificing any performance on the track. The 9MP system, which weighs in at just 2 kg, uses an actuation strategy called RLM (Rear wheel Lift-up Mitigation) that, as the name suggests, mitigates rear wheel lift in more abrupt braking situations; it can also be disengaged and it is adjustable to three levels easily by accessing the control menu on the instrument cluster.
- Level 1: this is dedicated to track use but is also approved for street use. It acts on both wheels to guarantee the best possible performance, even in the most intense braking conditions at any speed. It takes nothing away from the pleasure and performance of “extreme” riding. With this strategy RLM is disabled.
- Level 2: this is dedicated to sport riding on the road, acts on both wheels and is combined with the RLM tip over system which engages progressively based on the vehicle speed.
- Level 3: this is dedicated to riding on surfaces with poor grip, acts on both wheels and is combined with the RLM tip over system.
Each of these three Race ABS maps can be combined with any of the three engine maps (Track, Sport, Race), in order to allow riders with different experience and skill levels to find the best possible combination for their style.
DESIGN
Tuono V4 1100 RR is available in two attractive colour schemes, grigio Portimao and blu Donington
FOR THE FASTEST AND SPORTIEST NAKED EVER, A DIRECT DESCENDANT OF THE RSV4, FOUR-TIME WORLD SBK CHAMPION, A NEW EVOLUTIONARY STEP HAS ARRIVED WHICH ALLOWS EXCEPTIONAL LEVELS OF PERFORMANCE TO BE ACHIEVED. THE NEW, SOPHISTICATED ELECTRONIC MANAGEMENT INCLUDES AN ADVANCED DYNAMIC CONTROLS PACKAGE WITH APRC, CORNERING ABS, PIT LIMITER AND CRUISE CONTROL
THE INIMITABLE 175 HP V4 EARNS EURO 4 APPROVAL, WITHOUT SACRIFICING ANY OF ITS SUPERB PERFORMANCE. IMPROVED SUSPENSION AND BRAKES.
Simply unrivalled. Now more than ever. The Aprilia naked range, heir to a family of motorbikes which has been voted over time as one of the most adrenaline pumping and efficient bikes ever, achieves absolute performance levels and sophistication, thanks to Aprilia's know-how acquired over years of winning premier level competitions and the experience of the Tuono history, which is thus confirmed as the only superbike stripped down and fitted with a high handlebar, unbeatable on the track and loads of fun on the road. The Tuono V4 family of motorbikes is made up of two distinctly outfitted models. Tuono V4 1100 RR represents an exceptional thrill machine, the heir to a dynasty of naked sport bikes acclaimed by critics as the most effective and fastest bike in its segment. Tuono V4 1100 Factory is the more exclusive version, dedicated to an extremely demanding public; this bike is equipped with components which are largely derived from the Aprilia RSV4 RF superbike. The evolutionary step that Aprilia presents for 2017 involves both models that, as before, therefore continue to stand out for their factory outfitting and the graphics.
Completely revamped electronics
The greatest innovations have to do with the Aprilia Tuono V4's on board electronics, that has always been considered as the "best in class", where the APRC system stands out. Aprilia Performance Ride Control is the patented control suite derived directly from the winning technology in world Superbike, the most complete and refined of those available on the market. The fourth generation of APRC, standard on the Tuono V4 1100, fits in perfectly with the fine electronic management of the new full Ride-by-Wire throttle, that has allowed all superfluous throttle body electronic management components to be eliminated, thereby saving 590 grams. The repositioning of the inertial platform that allows APRC operation has improved accurate detection of the dynamic conditions of the bike, resulting in more efficient electronic control strategies.
2017 Aprilia Tuono V4 1100RR - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: See dealer for pricing in USD
Canada MSRP Price: $15,595 CDN
Europe/UK MSRP Price: £ 13,236 (On The Road inc 20% Vat)
Engine type Aprilia longitudinal 65° V4 cylinder, 4-stroke, liquid cooled engine with dual overhead cam (DOHC) and four valves per cylinder
Fuel Unleaded petrol
Bore and stroke 81 x 52.3 mm
Total engine capacity 1077 cc
Maximum power at crankshaft 175 HP (129 kW) at 11,000 rpm
Maximum torque at crankshaft 121 Nm at 9,000 rpm
Fuel system Airbox with front dynamic air intakes.
4 Weber-Marelli 48-mm throttle bodies with 4 injectors and latest generation Ride-by-Wire engine management that the rider can select on the fly. T (Track), S (Sport), R (Race)
Ignition Magneti Marelli digital electronic ignition system integrated in engine control system, with one spark plug per cylinder and "stick-coil"-type coils
Starter Electrical
Exhaust 4 into 2 into 1 layout, two oxygen sensors, lateral single silencer with ECU-controlled bypass valve and integrated trivalent catalytic converter (Euro 4).
Generator Flywheel mounted 450 W alternator with rare earth magnets
Lubrication Wet sump lubrication system with oil radiator and two oil pumps (lubrication and cooling)
Gearbox 6-speed cassette type gearbox
1st: 39/15 (2.600)
2nd: 33/16 (2.063)
3rd: 34/20 (1.700)
4th: 32/22 (1.455)
5th: 34/26 (1.308)
6th: 33/27 (1.222)
Gear lever with Aprilia Quick Shift electronic system (AQS)
Clutch Multiplate wet clutch with slipper system.
Primary drive Straight cut gears and integrated flexible coupling, drive ratio: 73/44 (1.659)
Secondary drive Chain: Drive ratio: 42/15 (2.
Traction management
APRC System (Aprilia Performance Ride Control), which includes Traction Control (ATC), Wheelie Control (AWC), Launch Control (ALC), cruise control (ACC) and speed limiter (APL), all of which can be configured and deactivated independently
Transport frame Aluminium dual beam chassis with pressed and cast sheet elements.
Sachs steering damper
Front suspension Upside-down "one by one" Sachs fork, Ø 43 mm stanchions. Forged aluminium radial calliper mounting bracket. Completely adjustable spring preload and hydraulic compression and rebound damping. Wheel travel: 120 mm
Rear suspension Double braced aluminium swingarm; mixed low thickness and sheet casting technology.
Sachs monoshock with piggy-back, fully adjustable in: spring preload, hydraulics in compression and rebound. APS progressive linkages. Wheel travel: 130 mm
Brakes Front: Dual 330 mm floating stainless steel discs with lightweight stainless steel rotor with 6 M50 4 32 studs. Brembo M432 monobloc radial callipers with 4 Ø 30 mm opposing pistons Sintered pads. Radial pump and metal braided brake lines
Rear: 220 mm diameter disc; Brembo floating calliper with two Ø 32 mm separate pistons. Sintered pads. Master cylinder with built in reservoir and metal braided hose.
Bosch 9.1 MP ABS with cornering function, adjustable on 3 maps, featuring RLM strategy and can be disengaged.
Wheel rims Cast aluminium wheels with 3 split spoke design.
Front: 3.5"X17"
Rear: 6.00"X17"
Tyres Radial tubeless.
Front: 120/70 ZR 17
Rear: 190/55 ZR 17 (alternative: 190/50 ZR 17; 200/55 ZR 17)
Dimensions
Saddle height: 825 mm
Trail: 99.7 mm
Steering angle: 24.7°
Fuel tank 18.5 litres (4-litre reserve included)
