How do you unscrew the TIGHT screws?
IHMJack
#1 Unread post by IHMJack »
I have alot of screws on my bike that I just cant take off, its just too tight.
I tried WD40 but I still cant unscrew, If I try to force it I may strip the screw. I think some of the screws are already striped, what should I do about those ones?
Help would be appreicated, thank you! :wink:
TechTMW
#2 Unread post by TechTMW »
You need an Impact driver - http://www.sears.com/sr/javasr/product. ... Cookie=Yes
if the other screws are truly stripped, you will probably have to drill them out.
storysunfolding
Years Riding: 22
#3 Unread post by storysunfolding »
If you stripped the screws, you might be able to get vice grips on them. That'll let you take them off and go find replacements. Drilling can suck but sometimes it's your only option.
My Blog
Grasp life by the handlebars
tcreeley
impact driver
#4 Unread post by tcreeley »
Impact drivers work well- always feels strange to use one!
Use the largest screw tip you can that fits the tightest on the screw without slipping or being loose.
Hold the impact driver hard up against the screw & and straight (not at an angle)
Use a 3 lb hammer (not less) and hit the impact driver a hard blow (don't kill it!)
Takes me 3 times before the screw loosens usually- I think it's more to get my nerve up to swing that hammer! Too light is useless - (but this is your bike you're smashing with a hammer!)
Watch your hand. ... It gets me- hex screws or allen screws would work great, but they use these stupid philips screws that strip. -Must cost to retool.
canuckerjay
Re: impact driver
#5 Unread post by canuckerjay »
tcreeley wrote: It gets me- hex screws or allen screws would work great, but they use these stupid philips screws that strip. -Must cost to retool.
ROBERTSON ROBERTSON ROBERTSON!
Wherever you may roam
May you own your road.
kar_the_terrible
#6 Unread post by kar_the_terrible »
if the screws are counter sunk and stripped you may have no choice but to drill them out. still use a left-handed drill bit to do so. That way the drill is rotating in the unscrewing direction and will eventually jar the half-drilled screw loose. Remember if you decide to drill it out, you should use a drill bit that no more than 80% the screw diameter or you risk destroying the threads in the hole.
If they are not countersunk, you can either make a notch in the head using a file and use a flathead screwdriver to get them out. Or vise grips are pretty good too.
'78 Yamaha XS400
'86 Yamaha Radian
rhost
#7 Unread post by rhost »
Use this
http://www.sears.com/sr/javasr/product. ... s+%26+Dies
Its made for stripped screws
